Noise level of your water cooler?
  • Noise level of your water cooler?
    I've been using a Lincoln Magnum 10 water cooler for the past few years when Tig welding. This cooler does a good job of cooling my HW-20 torch but I consider it too noisy. I can't measure the sound level I'm exposed to when welding but estimate that it's about 80+ decibels 5 feet away from cooler. Most of the noise is being produced, obviously, by the cooler's fan.
    Not having used any other brands of water coolers, I wonder whether any of you who weld with one consider your cooler noisy also. Brand X, is your Binzel cooler much quieter than other brands that you've used?
    LarryL
    The Miller Coolmate 3 is rather loud but I can still hear my cell phone ring while I'm welding. It is best to just use some hearing protection. I use the soft foam plugs that I use for shooting trap, comfortable and out of the way. It's always a hassle but I have friends that are in their 40's and already need hearing aids due to not using hearing protection at their high noise jobs.
    Bob Sigmon
    Dynasty 200DX and Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    O/A Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
    SkatBlast 970 Detailer
      Larry,
      I owned three coolers, A Benard 2500, Miller Rad. one, Binzel. The Binzel is a lot quieter then the other two. The brass gear Miller pump being the loudest. I guess the Binzel is made by Miller just in case you what to compare them to the coolmate 3.
      I do not find it loud at all, but I also have a air-cooled torch for real quiet operation.
      There is a large defence type contactor out here, that replaced all their Benards with the Binzels because of the noise factor. It was where I first heard of Binzel coolers.
      You might want to put yours on e-bay and check with me on a Binzel. I think mine was about $380/ $390 for mine from air-gas.I bought 3 gals of Binzel coolant for around 14.00 a gal but he also threw in a CK water cooled torch adapter into the mix. To help balance out the deal.
      Esab 2200 AC/DC
      Thermal 211i
      Thermal Pee-wee 85s
      Smith O/A plus mini torch
      Smith machine torch
      LN-25 pro
      LF-72 feeder
      Edwards 65 ton
      5X10 CNC table
      Victor A-120
      Miller Shopmate 300DX
      S-74D feeder
        Why is the Binzel quieter?
        Originally posted by Brand X
        Larry,
        Scott, if Miller makes the Binzel and it resembles their Coolmate, why did they somehow make the Binzel quieter than their own brand of cooler?
        LarryL
          The one that comes with the Syncrowave 250 package is so quiet that you need to look at the flow indicator to be sure it is running.
            Larry,
            The Miller that BrandX spoke of was a Miller Rad One. not the Coolmate.
            As I said mine is "loud", at least it is louder that if it is not turned on. It certainly is not so loud that I would change back to my air cooled torches. When it is on I can hear what is going on around me, like when the 200 turns it's cooling fan on or my cell phone ringing, etc.
            I also tend to use air tools to clean the area to be welded and they are very loud and whiney, hence the hearing protection. It helps across the board on random noise and I'll be able to hear when I'm older.
            Bob Sigmon
            Miller Passport
            Quincy QT-5HD
              LarryL
              Larry,
              I never heard how loud a Miller Coolmate 3 is. Only my Miller rad 1 and a few other old ones.
              Esab 2200 AC/DC
              Thermal 211i
              Thermal Pee-wee 85s
              Smith machine torch
              LN-25 pro
              LF-72 feeder
              Edwards 65 ton
              5X10 CNC table
              Victor A-120
              S-74D feeder
                I have a Lincoln Cool Arc 40 I purchased about a year ago and it is loud also. It's louder than the TIG welder...Precision TIG 375. It's nice when the welder automatically shuts it, and itself, off about 10 minutes after welding.
                TJB
                tjb
                  I had the Lincoln Magnum cooler on my Square wave tig 255 and it was very noisy,but now I have a Miller 350LX with the Miller V3 cooler and it is even noisier yet...I have often considered an air cooled torch,just to get rid of the noise..
                  tooldude56
                  Lincoln Square Wave Tig 255
                  DC600/LN7
                  XMT 304/64 feeder W/ digitals
                  Esab PCM-875 plasma
                  2 -Oxweld O/A ,W-17/CW-23 torches,R-77 2 stg reg.
                  new Clausing Metosa SM1560VS Smart lathe CNC/Manual
                  Wells index 12x48 mod. 847 vertical 3HP. mill,3 axis DRO,3 axis PF.,Maxi-torque-rite PDB.
                  Dake #3 arbor press
                  Kalamazoo H9AW hor. metal saw
                  16" Kolley vert. metal saw,
                  Trinco 36" blast cabinet with collecter
                  All Snapon
                  huge Summit vert. bandsaw
                  6x18 Reid Rollerway surface grinder
                    noise
                    What!!!!! I say What!!!!!
                      Revert back to my quiet, fanless tank?
                      I've used both foam plugs and full-cup hearing protectors when using my tablesaw, planer and other noisy tools. That's because years of working as an engineer in a factory may have caused me to lose some of my high frequency hearing, and, I want to keep what hearing I have left. I've not used ear plugs while welding, however, because it's just another thing to put on underneath my helmet. This morning, however, I put on some foam earplugs while welding and it dampened the sound considerably.
                      Another cooling option I've been thinking of reverting to is going back to my old 16 gallon cooling tank I used to use. It is just a plain steel tank on legs with an epoxy paint coating on its interior. I put a sump pump in it and fed the tank's water to my torch. It worked okay but I felt that the sump pump had too low a flow (probably due to its low pressure output) when I welded at higher amperages, especially with AC welding. This method of cooling was extremely quiet though, and, I usually didn't weld long enough to heat up 14 - 15 gallons of water. I'll have to look around for a vane pump that I can mount underneath my 16 gallon tank. This way I'll be able to have a quiet cooler to use when I'm welding at my table and a noisy Lincoln Magnum for use as a portable cooler.
                      LarryL
                        Larry,
                        You might try using coolant instead of water and you might have better results using your old system. The Miller coolant , while relatively expensive, has been developed to be non-conductive and has additives to keep the green algae away, etc. You could probably use it diluted and it would be better than nothing.
                        Hey, there's more than one way to skin a cat.
                        PS - No cats were actually skinned in the quest for a quiter torch cooler.
                        Bob Sigmon
                        Miller Passport
                        Quincy QT-5HD
                          Miller coolant is too expensive!
                          Larry,
                          You might try using coolant instead of water and you might have better results using your old system. The Miller coolant, while relatively expensive, has been developed to be non-conductive and has additives to keep the green algae away, etc. You could probably use it diluted and it would be better than nothing.
                          Bob, the cost of 15 gallons of Miller coolant would more than pay for my cost of a used vane pump and motor. If I go back to using my old cooling tank, I'll fill it with distilled water, which is also nonconductive. As a former chemical engineer I can't understand why the inexpensive ingredients in a gallon of coolant would make it cost so much.
                          LarryL
