plazma cutting patterns
  • plazma cutting patterns
    Just hit upon a good material for plazma cutting patterns -- PERGO laminate flooring.
    Use with the hard laminate surface up. Cut to shape with a fine-tooth band or jig saw. Flash zone of the cut erodes and undercuts the partical board substrait, but the laminate surface remains true after many cuts.
    moT
    Plazma Patterns
    Dear Sir,
    Would you build me some patters, of course I'll pay you.
    Product: Hypertherm Plasma 30
    Note: nozzle will have direct contact with metal.
    Patterns of value:
    1) stright cut (left edge would be 1/2 inch from actual line. slot
    where gun nozzle will slide.
    2) 1/2, 3/4, 1, 1 1/4 1 1/2 ... to 5 inches for bolt holes
    3) Figures - wolf, rabbet ... (I could supply some.)
    4) squares 1, 2, 3, ... to 8 inches.
    Thank you for taking the time to read.
    Vern
    480 963-2135
    Arizona
    My Shop Menu> - Web
    Vern
      Umm, Vern... look at the post date on this thread... That post was nearly SIX YEARS ago.
      Hobart HH 125EZ
        ...and if he sends them by snail Mail...it could be another six!!.
        ...Heck...draw 'em and cut 'em, you can tidy up the "hand cut" edges very easily with a flap disc on a hand grinder! Loosen Up!! Plenty of art on the web free...just print to the size you want, trace with carbon paper..or I cut them out and dust the back with spray glue, stick them down and spray around the edges with white spray paint...that works well where a lots of intricate tracing would be involved. I also use a quality opaque projector to 'display' it right on the sheet metal, trace with a sharpie, then just zip it out with the plasma.
          I agree with Hotfoot...draw it out and cut it freehand or make your own patterns. You will have fun just making the patterns. I have patterns of letters/numbers that I cut out from plywood with a jigsaw years ago. They may be charred and blackened a little in places but they still work fine. Here is a photo of a star pattern that I use a lot. It is very thin(probably 22ga). I just clamp it and trace around it with a silver pencil. If you start looking around, you can find all kinds of things to use as a pattern. I also use Hotfoot's spray paint method but I try to spray a very thin coat around the pattern...I don't like the smell of burning paint.
            After 6 years, you should be able to get some recycled Pergo flooring pretty cheap.
