I have a PowCon 250 amp DC inverter with wire feed. What are my options to convert to TIG?
TIG conversion
CV VS CC
Mike, its my understanding that this machine does both. The basic inverter is a stick machine and has a three way switch for stick/GMAW/FCAW-Spray Transfer. In corresponding with Arc Products they mentioned that a torch mounted remote is available for TIG. I have a spare flowmeter and hose and can get a cylinder full of Argon from a friend on long term loan; just need whatever else it takes to set it up.
Re: CV VS CC
If your machine doesn t have high freq or lift arc your going to have to scratch start the tungsten.
So your guarnteed that a foot pedal is not an option?
If the hand control is the only option for a remote, I might think about passing on it, but thats just my opinion because I have a difficult time using the slide version that I have at work for my option when I can t operate the foot pedal. I guess though if I used it as much as I do the foot pedal I might get a better feel for it over time . However it does limit you to certain ways that you can only hold the torch and operate the remote.
Almost forgot to metion for steel and stainless steel I use a 2% thoriated tungsten. This isn t your only option for these metal it was just the standard when I was taught, and I guess I ve just been stubborn about switching to a non radioactive tungsten.
I have more info, but my son wants to play his bingo game. Sorry he is more important. Im attaching a picture of an example torch that has the valve and 2 piece cable.Last edited by Dan; 05-01-2009, 08:18 AM.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
Torches
Cope,be sure to check out the weldcraft WP-9-P torch.I think thats the number?Anyway,the one I have on order is the 180 degree model.It has a removeable head,so you can put on a 70/90/flex head,and up to a 150 amp head on it.The power cable is the same in the 125/150 amp torches.Get the two piece torch cable setup,because it flexes much easier.I only bought one extra 70 degree head for $20.00.It will be cheaper in the long run just buy that one first.Then buy a WP26 if you think your going to weld thicker type metal.I do have one with a valve for lift arc tig with my engine drive.I think they have more heads for the WP-9P then I listed.I think its a cool setup.
TIG
Scott and Dan,
The unit has a solenoid for MIG, activated by the trigger on my MIG gun, but don't see how I can activate it with TIG torch. The remote on the back will work with foot or hand control. I am about to get a hand remote for stick if the price is right but I think I would prefer the torch mount for TIG. I had a Lincoln 225 amp AC/DC/TIG on an Onan 6KW gen set but a friend wanted it pretty badly so I sold it. His welder has managed to fry something inside, so I may be able to get the TIG part of it back. May be possible to run the High Frequency box from my PowCon.
Within last year someone posted on this board link to company that sells foot pedals for most any welder. I have also seen people adapt sewing machine foot control pedal to welding machine use by installing correct value potentiometer, cord, and plug. A pedal for older sewing machine works better as they have more room for modifications.Last edited by Roger; 02-09-2003, 10:22 AM.
Foot pedal
Roger,your post on foot pedals brought up something I was going to post.Here is something for Miller to do.I just thought I would give them first crack at it.Only because I been mean to them sometimes.
While at the dentist office to get my teeth cleaned,something caught my eye.The girl there using a air powered tool that had a electric foot pedal that was interesting.It was kind of domed shaped,and you could step on it from any angle to make it work.It was a very low profile setup,and seemed like a very nice way to control the arc for out of position tig work.Anybody that does not like torch sliders it could be a pretty good way to go.
Ok Miller,go to it.
I have a switch on my router table that is a air switch. It has a half round ball with a diaphragm in it that you step on to activate. It is connected via a tube to a air switch receptacle that the router is plugged into. It is only 15A 120V so maybe it would not work for what you need.bitternut
SCOTT V................YOUR NOT ANY MEANER TO US THAN YOU ARE ANYONE ELSE..........THIS IS AN OPEN FORUM.......... I TOO LOOKED AT ONE OF THOSE DENTAL AIR TOOLS YOUR TALKING ABOUT.....HOWEVER AFTER ORDERING ONE FORM THE LOCAL MEDICAL CATALOGUE IT WORKED SUPREMELY GOOD WHEN BUFFING METAL..............HOWEVER WITH A DREMEL IT DID THE SAME AND WAS LESS EXPENSIVE,....... THE ONE I USED WAS FOR AIR...........HAVEN'T SEEN ANY NEW ONES IN AWHILE..........ROCK
[email protected]
