Rocky
Last night at work I had to attach some 3" X 3" X .250 sq tube mild steel to an 8" mild steel Rd tube column with a .375 wall thickness, which resulted in needing to run some vertical up welds. Instead of using my normal technique for vertical up with MIG I decided to give yours another try. Last time I tried it I was pretty close to nailing it, but not quite there yet. This time around by my 3rd practice weld, I think I finally master the technique. Not bad considering this makes a total of 8 welds that Ive ran with this technique. I wish it would have been this easy back when I was in school.
Anyway, as usual I have a few trophy welds to show off. On the this first bead the wire was a little low and didn t quite fill the joint in the way that I wanted.
