for your HH175 I would recommend .035 solid core. I have used several brands. The Hobart Weld-it brand seems to be readily available. I have not done any flux core welding so I will leave that call to someone else
Do you have any more info on that "blue demon" wire? I did a web search and could not come up with anything. Always willing to try what works for someone else.
www.welding-direct.com sells "Blue Demon" wire. The 2lb spools of ER308L stainless, ER70S6 mild steel and 1lb spool of ER5356 aluminum, I have ordered from them have been "Blue Demon" brand. The 10 lb ER70S6 has been "HTP America Inc." brand. I've not had any problems ordering from them. Only problem is I think they still have a $50.00 minimum order.
AL T......... MUM IS THE WORD, OF COURSE IF THEY HAVE MUTUAL CONTROL OVER CHECK BOOK............. THE WORD WILL GET OUT.......YOUR CALL.........................................ROCK [email protected]
