I have had some success with my basic TIG setup running off my Champ 16 on steel. I do need a LOT more practive though. Yesterday I tried to weld aluminum for the first time with this setup. OUCH....I am having a hard time maintaining the arc, and the filler won't stick. Is it a matter of technique (practice, practice, practice) or is a basic TIG setup not capable of welding aluminum?
The setup consisted of 1/16 inch pure tungsten, argon at 15 CFH, welder on AC at 50 to 70 amps, and the aluminum was wiped down with acetone.
I expected it to be hard to start the arc because of the lack of HF, but it was VERY sensitive to the distance from electrode to the base metal. A slight increase in the distance would snuff the arc, and if I was any closer, the electrode would be in the puddle. I was simply trying to lay a bead down on 1/4 inch material....not trying to join 2 pieces. This setup works pretty well on steel set up on DCEN and using 2% thoriated electrodes. HELP! Thanks.
