wire spool
  • deere_x475guy
    Awh yes......I made one heck of a mess my first time. I learned to put the spool on....get tension on the brake...then very carefully pull the wire from the spool and start it in the guides..
  • Will
    Get a hold of the end of the wire with a pair of needle nose or MIG pliers....and don't let go until the wire is clamped in the rollers. It happened to me on my first roll.....noboby ever tells ya how bad that wire wants to be straight until it's too late!
    If you try to wind it back tight, that doesn't work well either. The layers get tangled up and make an even bigger mess. I guess everyone has to try it at least once!
  • Guest
    Re: wire spool
    Originally posted by star
    Maybe this question has been brought up before....is there any trick to keep 1 lb. spools from unraveling when installing a new one ...lost half the wire yesterday..Handler 135 works great !!!thanks & Happy Holidays!!!
    Welcome to the wonderful world of welding!! Happens to pros too!
  • Al T.
    After I've pulled the wire out to the drive pulley, I stretch a rubber band around the spool crossing over the wire. That holds it secure.
    I tried using the holes on the spool but that wasn't as easy.
  • star
    started a topic wire spool
    wire spool
