I was wondering if I used Stargon on stainless steel would it or could it eventually rust. Just picked up a tank to try and compare it to C-25 on mild steel as far as spatter goes, and I do have a stainless job coming up or should I stay with the A1025 mix of helium, argon, CO2 which I know will do the job right.
So two concerns
1) stainless st. gas
2) spatter : which is better stargon or C-25 ? The part I weld for customer is very hard to get into where I have to push the weld and the wire stick out becomes kinda long or longer than I like, hard area to see and get into. Its just fixtured that way and can't change it
So two concerns
