Can satisfactory welds on aluminum be made using a MIG welder and a spool gun? Or is this just a fantasy used to sell spool guns. I have no experience doing this. Every one I've talked to says it's a joke and the welds I've seen are the worst ever. Can it be done satisfactorily or not? If it can be done; what are the keys for success? Thanks, Ron
Aluminum MIG welding
Re: Aluminum MIG welding
Originally posted by Ronald 1
Can satisfactory welds on aluminum be made using a MIG welder and a spool gun? Or is this just a fantasy used to sell spool guns. I have no experience doing this. Every one I've talked to says it's a joke and the welds I've seen are the worst ever. Can it be done satisfactorily or not? If it can be done; what are the keys for success? Thanks, RonROCK
Ronald, absolutely and positively you can achieve x-ray quality welds with a spool gun. Set up including wire diameter, voltage, shielding gas and finally operator skill is all it takes. Simple, right? If you post your wire type and size, your shielding gas, the equipment you are using, and the technique (as best you can) you are using, we will set you up and you will be making great welds in no time.Respectfully,
Mike Sherman
Shermans Welding
