I just got my TIG (Miller Econotig) and instead of asking the same questions that have probably been asked 100 times before, I figured I'd ask if there are any good sites that have FAQs or Tutorials on TIG welding?
I do have a question I will ask.. I have a MIG and now a TIG. Is there any way to get away with only using one tank? Not so much the plumbing, but the contents of the tank. MIG uses the Argon/CO2 mix, and the TIG uses straight argon. Can either one use the other's gas? i.e. will MIG (for steel) still work OK with straight argon?
I've only played with the TIG for a couple hours, but it would seem my biggest problem is touching the tungsten to the work. it seems the tungsten gets contaminated and I have to regrind it in order to stop 'wandering arc'. Within those couple hours I must have reground the electrode at least 8 times. I'm assuming thats way above normal?
I was pretty successfull at cleaning up MIG welds with the TIG. (no filler). I just need more practice. And I was using a MIG tank.
Thanks,
Mike
Thanks,
Mike
