ok, something is wrong with the welder.
I switched back to .023"mild steel wire, and it'sdoing the same thing! I shouldn't haveto jack the welder up to the highest amperage setting to weld a 1/4" thick exhuast flange to 16g tubing. =( There was very little penetration. I should have been blowing holes in the tubng.
The wire feeds fine, but assoon as I start welding, the maching "surges" and won't feed consitently. The lineris almost new. The tip is almost new. I have a newly exchanged tank filled with C25.
Could this be caused by having the tension adjuster set too tight or too loose?
I just thought that the times this has occured I have been using an extension cord. Tomorow I will try hooking the machine up directly to the outlet and running a few beads.
Welding 1/8" 304 SS to 1/8" Mild.
Oh, I think you are right, JohnV. I don't think 309L is the fluxcore wire they are refering to. Thanks for catching that.
The_Beave...isnt 309L supposed to be used with a tri-mix? I dont think this wire is the wire that everyone was reffering to earlier in this post(gas shielded flux core)?
Franz-
This is the only welder I have available. I'll just have to make do. The welds seem pretty solid, just not pretty at all. Staten Island got 13" or so.
Roger-
How does one backshield a weld? Can one run a T in the hose from the bottle? I have searched around a bit, and haven't come up with the info on how to do this. (Granted, I haven't looked TOO hard.) When I weld up a SS exhuast for a freind, I will try the aluminum foil. That sounds rather spiffy.
Pturner-
The local welding supply company had 309L in a 2lbs spool for approximately $30+bloodmoney for the government. They don't move much of it. heh My boss purchased thier last roll before they reorder the stuff.Last edited by The_Beave; 12-08-2003, 11:51 AM.
Did you find the fluxcore wire in 2 or 10 lb spools? For the cost of a 28/30 lb spool, I could pay someone else to do it, but of course I won't.
Guest repliedYou needed to back shield weld to get better looking back side. If it was butt weld aluminum foil on back side to contain shielding gas might have been enough.
Beave, I think you hit the nail on the head when you said the welder is too small for the job.
If you have a stick machine available, you might try that with SS rod, and a copper or aluminum backer plate behind the light metal.
How much snow have you got down on the island, the talking heads on TV say there is 18" in Queens.
The welds held. That's about all I can say for them. They look like crap, and I don't think I'm using the right settings at all.
I was maxing out the machine (setting at D on the lincoln Weldpak 100) and had the wire feed set to about 5.5. That was the only setting that would produce decent, consistent penetration. however, the menetration was a bit too much, as the back of the weld "bubbled up."
Just to make it clear, I am using the Lincon Weldpak 100 (110V) with .030" 309L wire and C25 mix. I had to keep a VERY short stickout to get a consisten pool.
I don't realy expect much help, because most people here have better welders than I do. heh I have more work to do on the chute of the spreader, so I will keep posting as I try different things.
Ok, I'll take everyone's advice and get a refill of C25. I'll let you know how I do with it, because it wil be a DFO error not the gas' fault. =)
Guest repliedHere is .stainless steel .045 fluxcore wire made to weld from 18ga. to 1/4"
Hard to believe but setting chart looks like HH135 or HH175 could use this wire but it is on 28 pound rolls.
With solid wire in SS or mild steel you will get a very high crown on your weld with argon as the shielding gas as well as undercut on the toe lines of the weld, C25 would be a better choice.
I have welded with the flux cored SS wires on materials 3/16" and thicker with excellant results. I know that Mckay and Stoody make both gas shielded and self shielded stainless flux cored wires but I have not seen it in spools smaller than the 12" 25# package.
The .045 309L flux cored wire will run with CO2 or C25 but requires at least a 200 amp power supply the recommended current range is 24-26 volts at 180-220 amps. If you can find it in .035 dia it will still require 110-180 amps at 23-25 volts.
Has anyone found this wire in a smaller spool size? Please post the retailer you bought it from.
Thanks!
John
Guest repliedGas shielded flux core, metal core, and hard surfaceing tubular wire uses DC+ just like MIG.
Gas shielded vs self shielded. Both are a tubular wire, hence the "T" in the designation. One uses an external gas for shielding, one does not. I am trying to keep it simple here. I am not aware of any self shielded stainless flux core.
Originally posted by morpheus
What is the difference between gas shielded flux cored wire and just flux cored wire or are they one and the same ?
PS: someone correct me if I'm wrong, but I don't think they make a self shielded stailness flux-core wire.
