Trying to weld some 1/8 plate just got the machine this week I can't establish a arc it jumps around buzing and leaving black pitted metal until it burns the tip. have tryied many of the setups for the machine listed prevous on the board it does this no matter what the settings. also it has poped up e03 code 1 or 2 times. it seems to work fine in DC.
T/a 185 aluminum problem
Are you using an extension cord from your 230V supply to the welder? If you are is it number 10 wire, smaller wire may cause a voltage drop and give you an error code for low input voltage.
Does the aluminum you are attemting to weld on could have an anodized coating on it ?
Suggested starting parameters for 1/8" aluminum
shield gas: Argon 15 - 20 CFH
Tungsten: 3/32" thoriated or lanthinated (pointed for arc control)
set for AC HF tig with foot control
Initial current: 20 amps
Weld current: 125 amps
AC blaance: 20 - 30
AC freqency: 60 - 80
Post flow: 3 - 4 sec.
tungsten to work distance 1/8"DrIQ
