Yesterday while in the basement drilling holes in the floor joists to run some Cat5e computer cable, I miscalculated and nicked the bottom of a piece of 5/8" O.D. Type L water pipe. The result is a pin hole leak that sprays a very fine mist of water from the hot water pipe. As luck would have it, this particular area has some soldered elbows and Tee's in the same area with the closest one being a tee that is approx 4 1/2" from the leak. I just plumbed this area in May when installing a new hot water heater, and if at all possible would like to avoid having to deal with soldering these joints again because of the area that they are located in.
I was thinking of just cutting the pipe at the leak and soldering a sleeve over it, but like I mentioned above there is a tee soldered about 4 1/2" away and I am pretty sure the heat from installing the sleeve would melt the nearby joints which would require re-soldering all the joints in this area. Any ideas on how to repair this leak without doing a major overhaul..........Thanks
