left to right?!
  • left to right?!
    Gentlemen,
    I was making my welding cart tonight, and for some strange reason I tried welding from left to right...it turned out really well, because I had my hand planted on my work so it was really steady.
    using flux core currently (until the spool is spent). anyone have any input whatsoever on this?
    I don't know welding. I know computers. Got computer problems?
    Nothing at all wrong with going either way. In fact I would say that will help you in the long run. I'm left handed so its more comfortable for me to weld right to left. Many times I find myself in a position to weld left to right. Sometimes there just no other way I always suggest to people once they are comfortable welding the way thats most comfortable practice what is most uncomfortable you'll be a better welder in the long run.
      being steady and comfortable is the key ...other than that your right handed and was pulling the puddle ...you get that mail about the puter tools????
        but technically I wasn't really pulling the puddle...not sure what I was doing really...but the weld looked good for once.
        BOILERMAN--
        were you saying you sent me an em9ail with a computer question? It didn't make it to me...you can send me an email directly at [email protected] and I'll do my best to get back to you in a timely manner.
          Kfriend,
          You actually should be dragging the weld when using a self sheilded flux cored wire, the old rule of thumb is "if there is slag you drag". Now as with any rule there are a few exceptions but from the sound of what you are doing you should be dragging.
          When you switch to a steel hard wire with a sheilding gas you can either push or drag the weld.
          When mig welding aluminum you should always push the weld.
          I hope this helps....
          Kevin
