Assuming you were cutting a piece of 1/8"x1 1/2" flat bar in a chop saw with it laying flat in the vise. Which is the best way to cut it? With the blade contacting the front (part closest to you) of the material first, the center of the flat bar or the rear of the flat bar? Thanks......
Chop Saw question
Do NOT cut flat bar verticaly. After the abrasive blade gets hot, you will NOT get square cuts.
As far as where to start the cut, first off, I've never used a chop saw that was adjustable that way, and second, I really don't think it matters. If it cuts, it cuts.
Sorry, Mike I have to disagree with you...I always cut flat bar vertical. If the blade doesn't give you a straight cut, the problem is in the blade, or the saw, or both. I have a makita that cuts perfect every time and its' 15 years old. i also have a Dewalt 871 that is new, and I have never had a decent cut on it. (see my previous post on it). I have used HF blades and have had good luck with them. The Dewalt blades do bend, and IMHO are too dangerous to use.
Originally posted by Rocky D
Been busy doing dogs....it's more work than welding.
Glad to see you back, Rocky....I tried one vertically last night and it doesn't get nearly as hot as cutting across the flat. As for straightness, it was as straight I guess but I do know that the blade flexes. It's a DeWalt blade. Are you saying that the blades from HF are better? If not, in your opinion, what blades do you suggest using?
Originally posted by Mowjunk
Doing the dogs or going to the dogs????
Yeah, we just had three litters a week apart, keeps us pretty busy. Got one more this week to do.
Good deal, Rocky....That's what I needed to know. I still like those dogs you raise. One day.......maybe in the not too distance future, when I retire and have more time to spend with it, I might look you up for one of those pups. In the meantime, I have Mr. Heinz57...lol.
Thanks to all who replied. It's good to have information like this basically at our finger tips.
