I would like some advice on using the Hobart 135 for welding aluminum.
My problem seems to be that the wire ***** up and sticks to the end of the gun upon the initial arc. When this occurs, the drive wheel bird nests the wire. I'll bet I've got almost 200 ft of 10 ft sections wasted on the shop floor due to the bird nests. When it works like it should I have no problem actually welding aluminum.
Are there any tricks to getting the wire flowing like it should?
Here's my setup. ER4043 wire size .030", .035" tip, Argon gas - pressure gage=20, heat setting = 4, speed = 90.
I've also had the liner as close to the drive wheel as possible. That still doesn't help. I've tried wire stick out from 1/4" to about 3/4". Speeds from about 80 - 100.
Very Frustrated!
Very Frustrated!
