I'm getting ready to shorten a frontend axle for my jeep project...the inner "c" knuckle needs to be welded back on to the tube...can I use a 220v mig machine?...will that be powerful enough? most people recommend stick but i don't know how to stick weld...thanks
axle tube welding
Re: axle tube welding
Originally posted by double R
I'm getting ready to shorten a frontend axle for my jeep project...the inner "c" knuckle needs to be welded back on to the tube...can I use a 220v mig machine?...will that be powerful enough? most people recommend stick but i don't know how to stick weld...thanksMigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
I'm getting ready to shorten a frontend axle for my jeep project...the inner "c" knuckle needs to be welded back on to the tube...can I use a 220v mig machine?...will that be powerful enough? most people recommend stick but i don't know how to stick weld...thanksROCK
Could use MIG welder or stick welder for welding togeather your axle tube assembly. Easy weld for a pro but not the place to learn welding. Must also deal with alignment problems. Check angle before and after welding with angle finder seeing that both sides retain same caster.
I'm in the middle of doing this myself. It's doable with a 220V welder assuming the machine is big enough. I'm gonna use a friends 250 amp ESAB to do the final weld.
How thick is the wall on your axle tube ? mine is 1/2" thick ...
- jack
Re: Re: Re: axle tube welding
it's 1/2" thick as well...it's a 3/4 ton dana 44 front...
However, in the end I think I would probably use TIG . I d have to rent the machine though, because my Econotig couldn t handle the job.Last edited by Dan; 10-16-2002, 11:17 AM.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
