Acid Etch Test Question
  • Acid Etch Test Question
    I have no formal welding insruction, but have been MIG & stick welding for a while. I've always checked for welding penetration by cutting a test weld on a coupon in half, sanding it smooth, polishing it and looking at the penetration with a magnifying glass. Or just try to break the test pieces with a BFH !!
    I'd never used the acid etch test before reading about it on this forum, so on my last test, I put a few drops of Muriatic acid, which the label says contains Hydrochloric acid, on the cut & polished end on the coupon and let it sit. After the acid dried, I don't see ANY difference in coloration between the base metal (1/8" CRS) and the weld (MIG). Is this acid too weak or am I doing something wrong?
    -Bob (JalopyBldr)
    HH187
    13" SBL
    See if you can buy some ammonium persulfate. It should have better contrast between base and weld metal and is safer to use. Dilute [5-10%] nitric acid in alcohol should also work.
    Hobart Betamig II
    Hobart Betamig 170
    Lincoln Roundtop 250 (Stick/GTAW)
    Clausing 5913 Lathe
    Gorton 1-22 Mastermil
    Johnson J Bandsaw
    3HP 220V Chop Saw-Chain Drive
    "You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
      I on't let the acid dry. I let it sit for two or three minutes and then rinse the coupon with plenty of fresh water. I've used muriatic, but nitric seems to work better.
      There is not a major difference in coloration, but the fusion line is much more clear, which is what you are trying to see. A bead "layed on top" will show a distinct dark line between the bead and the weld metal, indicating lack of fusion.
      Hank
      ...from the Gadget Garage
      MM 210 w/3035, BWE
      HH 210 w/DP 3035
      TA185TSW
        NItric acid nasty stuff!!!
        What concentration do you use it in?
          I use muratic acid in a 50/50 consentration and leave it in about 30 seconds.
          Regards, George
            Hmmmm......danged if I can see any distinction to show weld / base metal separation. I'll try it again, guys.
            Thanks for your responses.
            -Bob
            -Bob (JalopyBldr)
            HH187
            13" SBL
              I've been using Naval Jelly. Let it sit three or four minutes, rinse off and you will see the penetration.
              Don
              Go Spurs Go!!!!!!
                Pete,
                I'm not sure, since I don't have any right now, but I use it right out of the container it comes in. I'm sure it's weak - but I'll find out and let you know.
                Hank
                MM 210 w/3035, BWE
                HH 210 w/DP 3035
                TA185TSW
                  Dosen't the BB lint that comes in that stuff get in the way
                  Regards, George
                    I dissolve about 1cc of concentrated in about 20cc of denatured alcohol for this. Metal wants to be warm, not hot (80F or so). A couple miinutes, then rinse. I have concentrated at work (job 1) for an assortment of uses. Etch solution doesn't even show on the log sheet. For more info, look up 'Nitol'... (http://list.uvm.edu/cgi-bin/wa?A2=in...safety&P=17877 , for one)
                      I haven't had a problem with it.
                      Don
                      Go Spurs Go!!!!!!
