I know this dosn't pertain to welding, but can anyone tell me if there is some sort of bit that I can use in a radial drill press to create slots in say 1/8th" to 1/2" steel plate or tube. I have been just drilling then filing them, but I would like something that looks a little more consistant with a machined look............thanks
Making slots
Thanks PSD KEN and Franz.
Franz,
By the drill press being solid I take it there should be no wobble or play in the chuck or supporting/slide arms. Also, could you please explain what a slot bushing is ( I have very limited machining experience....none come to think of it )......thanks.
Radial arm drills normally move the drilling head into position, and then aren't locked until the drill bit is indexed into the drill bushing on the template.
A slot bushing would be like a drill bushing, but would have a continuous slot rather than an individual hole for a drill.
Since I don't have an idea if you're using a Walker Turner radial, or an enco homeowner radial, it's a bit difficult to come up with a solution to your problem.
