Face Hardening
  • Face Hardening
    Need some general input on face hardening and rod selection for SMAW. Process will be used on bucket teeth ( backhoe, excavator, etc). And loader bucket cut edge. Machines are used in rock and shale digging and loading. Weld machine is a Champion 10,000. Thanks in advance.
    GWR
    GWR
    I use Lincoln Electric Wearshield M/E (metal to earth). Most manufacturers have a product similiar to this. Run stringer beads, overlap them and don't be concerned if the beads crack, it is normal.
    Respectfully,
    Mike Sherman
    Shermans Welding
      GWR,
      A couple weeks ago I attended a welding show and talked with the rep from Stoody. I have never used their products, but according to the catalog they handed out, they seem to have a rod or wire for just about every hard facing need. The rep also stated what Mike Sherman did about the weld bead cracking, and I guess this is the normal result of the rod or wire doing it's job. www.thermadyne.com/stdy/index.asp?div=stdy
      Pat
        As I understand it (from the (gasp) Lincoln site) hard facing rod alloy sacrifices all ductility/toughness for wear resistance. They virtually guarantee the deposit will crack as it cools.
        Blacksmith
        Stickmate LX AC/DC
        Big cheap (Chinese) Anvil
        Hand cranked coal forge
        Freon bottle propane forge
        HH 210 and bottle of C25
          Stoody makes excellent hardfacing rod.We use to weld with there nicromang and had great results with it.And as far as cracking,avoid wide weaves and keep the interpass temps under 500 degrees.
