I must confess that at this point MIG scares me a little (OK, a lot...). At school I have been practicing on 1/4 inch material running around 25 Volts with the Millermatic 10A wire-feeder at setting 38 (whatever that correlates to in IPM) with C25 shielding gas at 20CFM. Is this a Globular transfer setting or is it still in the short-arc range?
Today I decided to practice on 1/8 steel and I set the machine to 22 Volts trying to run short-arc. I adjusted the wire-feed until I got what I think is a decent bead profile, then ran a fillet on one side of the 1/8 steel. The bead looked great until I hit the steel with a hammer and the weld came unglued after two strikes... There was NO penetration into the base metal.
I repeated the experiment with the machine set back at 25 Volts. I beat the vertical plate flat onto the fillet and had a heck of a time bending it back up straight again. The worst it showed was a crack along the upper toe of the fillet weld, but it never gave up...
Is MIG really that unforgiving or am I just doing stupid things? It is scary that a decent looking weld can fail that easily. I admit that I did not clean all the mill scale off, but the arcs were steady in both cases.
Any feedback? Thanks!!!
