arc force miller exp.
  • arc force miller exp.
    Hobart-Miller expert Rock: Hey Rock I have a ? I have a couple of 6pack miller Mark V1 My ? is does the arc force stay on when the smaw is off while tigging out -put control is both on remote. Thanks Stu 169
    STU BASS.............HEY THIS ONE IS FOR SERVICE (DAVE IN TIG) I'VE NEVER SET DOWN WITH ONE OF THESE MACHINES..... IF HE IS NOT IN I WILL ATTEMPT TO ANSWER FROM TEXT BOOK (SERVICE MANUAL)..................... I'LL E-MAIL HIM NOW.......... GOOD QUESTION............................ROCK.......... .... NOT ALWAYS A KNOW-IT-ALL...........................
      Rock: Thanks. I believe I know the answer but need confirmation. The mach. setting calls for a 0 setting on gtaw. While tweeking the mach. for max penetration in the 6g posi. with 70s & 309 S.S. have found that with main power setting at 100 and remote at 75-85 range I need the arc force between 20&30%. Now I have to try and explaine to some of the apprentices why do you use a setting other than what is recommended on the mach. Must understand these are fairly new people tp the welding game. Thanks in advance Hobart-Miller Exps. Stu
        Stu,
        When you turn the SMAW switch to off position on the Mark VI you are disabling the arc force adjustment (a 0 setting). When Tig welding with any machine you would always want the arc force (dig) set to 0 or turned off as this will have a negative effect on your arc.
        Kevin
          Kevin: Thank you I agree with you. There must be a problem with our 6-packs or possible wiring? While tigging you can turn the arc force up even tho smaw is off. Tried it at 0, 20, 50, &100 of force. The higher the force the more unstable the weld puddle. Seems to run real good at 20. With 70s & 309ss. Is there a possible adjustment to the force control? Both 6-packs seem to be the same. They are only a year or to old and used for our welding school. I'am going to use them as they are for this week, It's the last week of testing for a few weeks. But if there is something I can check-out or have checked I will. If it was just one mach. and not the whole bank of 2 6-packs I would say it's a bad mach. And send it out for repair. Maybe doing something wrong? Arc force 0 smaw off 2 swithches on remote , mach. set at 100 at booth is on and set at 85. Thanks Stu
