Thin metal
  • Thin metal
    New to autobody welding. I am getting quite a bit of blow through while butt-welding 22ga. metal. The seam is tight and fit up pretty well. Using a small Hobart mig 135 on gas, .023 wire, lowest amp and wire feed settings. What gives? Thanks
    Some things to try follows;
    1) position part for down hill drag.
    2) use fore-hand push if you can't use tip #1
    3) increase your electrode stickout
    4) 'Skip' the arc
    5) try a Argon/oxygen mix say 2% Ox
    By "skip" think of your arc as pebble you want to skip across a pond. Rotate your gun hand closer to the work surface and rotate your contact tip upward (within reason).
    Ok, I don't mean bouncing your arc mostly what I'm trying tosay is turn the work angle in such a manner that the arc force is reduced because of the shallow angle. If you point your gun straight into the material you will blow right through-dig?
      Planet X, I can't believe you explained that well enough to understand... you musta wint to kolidge.
      Impressive, dig?
        I think your problem is more related to the joynt design than it is to welding.
        Most autobody patching is done with a lap joynt. There is a nice tool that downsets the metal and punches holes so yu can easily plug weld the patch in place that you can buy for under $50-.
          ROGERK.............WELCOME ABOARD......... DID ANY OF THE INFORMATION PROVIDED HELP OUT........... SOMETHING TO ALSO CONSIDER IS WHAT TYPE OF GAS ARE YOU USEING........ALSO A DETERMINING FACTOR.......................ROCK..........
            Re: Thin metal
            what gas are you using?
            ROCK
              Hey, Thanks for the input guys. I have some of my problems solved. I increased the angle of the gun and running a bit of a longer 'stick out'. Welded quite a bit today with no blow throughs. I am using a C25 mix. Thanks.
