Need a Converter Box for a SA200 Lincoln welder
  • Need a Converter Box for a SA200 Lincoln welder
    I need a converter box on my Lincoln SA200 F163 for the DC receptacle on the welder. I want to convert the 110DC to 110 AC so that I can run other electrical equipment from the welder. I was told a "Converter Box" is available. I would appreciate any help - many thanks,
    Pollock
    Good luck.
      Good luck does pretty well cover it
      200 amp tig rig- $175
      shade 12 lens- $8
      Tilman 850 elkskin gloves- $23
      Flushing-out your side 2 passes ahead of your brother in-law. PRICELESS
        Go to Sam's club, B.J.'s, or Northern.
        Get a good sized inverter.
        I put two 700 watt inverters on my pipeliner a few years back for the 'fancy' equipment that needs ac voltage.
        Use the dc for grinders and saws.
        steelhanger
          Yup, thats what I would do but more than likely would hook it to the truck which has a better alternator if I needed to run tools. I have also seen them with the alt replaced with a 120V gen head and use a battery charger for the unit. Obviously for small stuff this is great, bigger you need to get a different machine.
