safety: Cutting open Freon tank
  • safety: Cutting open Freon tank
    I'm pretty sure I know the answer, but better safe than sorry...
    Are there any safety issues with cutting open a used 30 lb. Freon 22 container? How about welding on it? I don't think that freon is an issue, but I was wondering about oils, or other additives that may be present.
    The end use is a small aluminum melting furnace (for green sand casting). My current cutting options are OA and bi-metal blades.
    Here's where I got the idea:
    Barry
    Use a saw, Freon when burned produces phosgene gas. The results of breathing it can be fatal. There will probably be a bit of oil present, but you can clean the interior after cutting.
      I made a blacksmithing forge from a freon tank and I cut it open with a saber saw and bi-metal blade. Same concern, I didn't want to create phosgene by using a torch. It cut really easy.
      Blacksmith
      Stickmate LX AC/DC
      Big cheap (Chinese) Anvil
      Hand cranked coal forge
      Freon bottle propane forge
      HH 210 and bottle of C25
        Re: Cutting open Freon tank
        I didn't plan on it either, problem is I simply forgot about the risk. After I staggered around the garage for a few minutes, I put down the torch and picked up the saber saw.
          Thanks for the info.
          Barry
            THINK OUTSIDE OF THE BOX!
            Have whoever you get the freon tank from hook it to the reclaimer and suck it down to as close to 30" of vacuum as he can.
            Freon doesn't permiate the steel the way Propane does, so there is no residue.
            A torch is overkill on Freon tanks, plasma works great, these tanks aren't 1/4 the thickness of a Propane tank.
