I've got a millermatic 130xp I'm having some problems with. I bought it used and I'm not sure about the history and if everything works. When I'm using gas, co2, I can't turn up the wire speed very high. Above 50 it pops and I can't run a bead. I was doing some t test welds on some 3/16" mild steel. The recommended settings on the machine were volt setting 4 and wire speed 70. Couldn't lay a bead. Switched back to flux core and I was able to put a bead down with whatever wire speed I wanted, on the same metal. The machine seems to work good with gas at the lower wire speeds. I don't have a flowmeter, I have my regulator output set at about 25-30 psi. I did change the polarity. Just looking for tips and opinions on what to check, etc..
Thanks,
Thanks,
