tig on a cst
  • tig on a cst
    what equipment would i need to tig weld with cst 250 any special torch or anything and how would i hook it up thanks.
    Bill
    mm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
    just an other traveling man pennmorris 778
    Wildbill,you would need a two piece torch with a built in gas valve.A bottle of argon,and regulator.You will also need a remote current control of some kind(hand,or foot)Then you will be uptown with that unit.
      scottv, thanks alot that advice was on the same wave legnth that i was thinking but really didnt know what it was called , thanks alot ill get on that. once agian thanks alot
        well i got the stuf and been welding all day , man its smooth for a machince designed as a stick welder , the lift arc is sweet i love it takes a wihle getting used to the valve and i got finger control instead of the foot pedal it takes up less room if by any chance i need to tig in the field, but im thinkin of getting a foot pedal for the shop, its not as smooth as footpedal but other then shortcomings due to my budget i love it and ioll recomend it anyday
          WILDBILL.............AH ANOTHER SATISFIED CUSTOMER....... AND CONGRATULATIONS.................ROCK.............. .
