I have been using my 30 amp clothes dryer circuit for occasional stick welding with a Hobart Stickmate 225 AC welder. I assume that, since the welder calls for 47.5 input amps to get max output, that I am limited to somewhere around 140 amps output with my 30 amp breaker. If I buy a 225/160 amp AC/DC welder, will the DC output be limited to around 100 amps? If this is the case, will that be enough output to be of any practical use? I doubt that I will be welding anything much over 1/4". If the 100 amps DC is enough, what rod do you recommend.
