Hi all. I am not new to TIG'ing aluminum, however I am new to thin sheet and am having major problems!!! I'm building a few gas tanks for a friend and am using .063" aluminum sheet. This is way thinner than I'm used to and when I try to tack it up, it looks like there's major contamination, yet sometimes it tacks just fine. (first picture proves this) I don't use any filler to make my tacks, and this works great on .090" and up. I've tried everything I can think of!! Following are different things I've tried:
cut with: shear, jigsaw, skillsaw
edge prep: none, 120 grit flap wheel, acetone, mek, 3M hand pad
welder: ramp up on power slowly, full power at once, tried from
10 - 30 cfh w/ #8 gas lens, 1/16" & 3/32" pure tungsten
And believe me, I've tried every combination of these things I can think of! I have no problem with fillets, butt welds or lap joints, just the corner to corner. I'm running a miller 180SD w/ pure argon. I've also tried a new bottle of argon... no difference.
I'm sure I've forgotten some details and sure you guys will remind me. I'm including some pictures of flat beads just to prove I can weld, but I have no idea what I'm doing wrong on the little stuff!! six pictures follow:
