I own a MM210 in which I run .030 Hobart wire along with C25 for shielding. I was working with some 1/4" flat stock, welding it to some 3/16" wall rectangular tubing and was experiencing a lot of popping and splatter while it was on a tack 4 setting and at 62% wire speed (which is what 1/4" is recommended at with .030 and C25)
When I'd put it down to the recommended setting for 3/16" which is tack 3, and 50% wire speed, it would sizzle nicely w/o any pops or splatter.
Why would 1 setting higher make it pop so badly like that? Is that a sign of too much voltage/amperage for the .030 to handle? I tried speeding up the wire to 65% while on tack 4, but it still popped away.
BTW, running the C25 at 20cfh to start out, increased it to 25cfh with minimal improvement.
I couldn't seem to get it to weld nicely while on the recommended 1/4" setting of tack 4 and 62% wire feed. Can anyone offer any suggestions?
p.s. I did have the work freshly ground and even tried wiping it down with some brake cleaner spray which made no difference.
