I need some help on welding a corner joint. First I'll tell you I have a MM210 using .035 wire and 75 25 mix gas. My problem is should I use a stringer bead or a weave pattern? The steel is 1/8, when I run a stringer bead it just kinda looks like blobb. I mean it's even, there's just no ripple to it. I tried the weave and it doesn't look much better. I went by the setting inside the door, I know that they are close and I might need to adjust. All my other joints have a nice ripple to them. I ran a stringer bead on a lap joint and it rippled niceley, same steel same settings. I pretty new to all this, I 've only had my welder for a little over a week. I know it's probably hard to say without pics. I have a digi. camera but I can't get a clear pic thats close enough to see anything. Anyway any help would be greatly appreaciated.
Thanks, Albie
Thanks, Albie
