Srubrn: MM 210 welds and settings
  • Srubrn: MM 210 welds and settings
    Hey Todd
    This last weekend I ran some test welds on some .063 wall 1" sq tube for you. I ran welds with an .030 and .035 E 70S-6 and C25 shielding gas. For the .030 wire the settings on the door of the machine worked perfect for me. With the .035 wire the setting on the door was a little hotter then I liked. In the end with the .035 my settings were voltage tap #2 and 25 on the wire speed. Now, I had planned on posting some pictures of these welds for you. However, my wife did some cleaning around the house yesterday, and so far I haven t been able to find the pieces so that I can take some pictures of them. If I happen to find them I ll take some pictures and post them. Oh, by the way between the .030 and .035 , I liked running the .035 wire better. However, please keep in mind that I have always used .035 wire for 16ga. so the .030 is new to me.
    Now, along with the 16 ga I also ran some welds on some 3/16" mild steel. For this I only used an .035 E70S-6 and C-25. I had these test pieces out in the shed with the welder so I was able to take a few pictures of them for you.
    So, lets get to showing the pictures. This first weld is a horizontal T joint. I ran this weld using a circular (oval) oscillation. Machine settings were voltage tap #3 and 38 on the wire speed. Now I only use this oscillation for non-critical welds. The most common time that I use this oscillation is when Im welding on a project that contains 1/8" and 3/16". This allows me to use the same machine settings for both thicknesses, so that I don t have to keep going back to the machine to change my settings. On the 3/16" I use this motion and on the 1/8" I travel straight or use a slight side to side wiggle. Anyway here is the picture.
    This next weld is a horizontal lap joint. Machine settings were voltage tap #3 and 42 on the wire speed, which are the settings off the door of the machine. These settings were perfect for me.
      This last one is a vertical up T joint. Machine settings were voltage tap #2 and 35 on the wire speed. Oscillation was a triangular weave.
        Beautiful welds Dan. When are you getting the 251 so you can do that for me..?..)))
        Short Term Memory GONE!!
        Hobby Weldor/Machinist
        Photobucket Shop Pics
          Bob it's been 2 weeks,you should be posting your own welds like that by now ,just think you will have that bad boy all tuned in and Dan will be asking you for settings
            Dan,is it true that there is no code for backstepping when mig welding?I heard the Esab rep say something like that.He is a pretty fair welder in his own right.I kind of thought he knows what he is talking about.I don't know what weld joint he was talking about.
              just feeling sorry for myself. **** Dan you rock.
              I don't know welding. I know computers. Got computer problems?
                Well, actually once in a while I do get lucky and get somthing close.....but I never get two in a row so I can prove it wasn't just luck like Dan can......
                Actually I haven't done much welding with it at all. Once I get all the metal cut for my bucket then I will have alot to do......Yippie...
                  Dan,
                  Thanks for all the help. i am goingto the shop wed and will try some of that.
                  What are you doing welding in the house for? Or was your wife cleaning your shop, if so, how did you get her to do that?
                  Todd Eldridge
                  Newbie Hobby Welder
