In my business part of what I do is Tool & Die repair welding where I need to heat the tool steel to a certain temp. I built a oven that is 4' x 4' x 3' high and my buddy helped out with adding electronic ignition and a digital readout thermocouple.
The oven will reach approximately 700 + degrees. I have four pipe or gas runs every 12" on center say by about 4' long. I used a plug with a # 30 drilled hole for a orifice, then the 4' pipe slides over and in this 4' piece I have an area cut into for air to be induced by pushing bar that is connected to slightly larger pipe which opens slot in 4' pipe. I added this for air into system and it created a slightly bluer flame which you can hear becomes hotter and workes well.
Now the question, I want this to get even hotter say 1100 or so for stress relieving of weldments. I heard that if I induce the oxygen or air into the system before the orifice it would increase the heat, presently I am introducing air after orifice.
Any thoughts guys
Any thoughts guys
