I read into and discussed in detail the requirements of welding aluminum with my Hobart 135. I changed the gun liner to the teflon coated, got a new bottle of straight argon, even bought new tips. I have the same problem over and over again: the wire (.030 4043) does the "bird nest" repeatedly right in front of the drive roller and tensioner, sometimes while trying to feed the wire through the gun. I checked the liner for kinks, made several tensioner adjustments, tried different speeds (75 - 90) same results. I tried to manually feed the wire into the gun, and it seems that there is a spot 3-5 inches from tip exit that the wire seems to hang up. If by chance I am able to get the wire to feed through, I have been able to run a few beads on some practice pieces, and after a successful bead when I stop and try to start again, birdnest. No other parts have been changed other than the liner and the tips. Stumped is my word of the day.
-Bobby
-Bobby
