Plasma cutter starting problems??
  • Plasma cutter starting problems??
    Bought a Miller Spectrum 625 and was working great. Now I have a terrible time starting a cut. Pilot lights, but does not seem to jump to material. Been just cutting carbon steel, light gage. Cleaned everything and made sure of a good ground. It may be something simple, as never had any other experiance with plasma. Any help would be great. Thanks
    That does sound like an open ground...maybe broken ground wire or loose connection?
      Hey, did you try to replace the tip, and the electrode inside of the cup, mine can sometimes get fouled and will do the same thing.
      Thats why I buy complete replacement kits, if you have a spare set give it a try.
        TOOMANYJEEPS.............WELL WHERE DO WE STAND NOW..... PROBLEM SOVED OR DO YOU NEED SOME MORE HELP FROM DANV YOUR CALL JUST LET ME KNOW..................ROCK..........
          Sorry, I was busy. One of my boys came down with a bug. I will try to get out there later today. Thanks
            Hope the boys OK
              Boys are doing good, except they passed the bug onto me and the wife. As for the 625, changed tips and works fine. How long should you get out of them?
                Depends on the materails, and the ammount of time you cut with the machine. Also the air quality has a lot to do with life span.
                Get Better
                Bernie
                  TOOMANYJEEPS........AIR QUALITY BEING OIL AND WATER WILL RUIN CUTTING TIPS IN ABOUT 1/2 THE NORMAL TIME....... ERODES THEM VERY FAST...........ARE YOU RUNNING ANY MOISTURE TRAPS OR NOT.............?....................ROCK......... ..............
                    Yes, went and checked my filter/dryer set and they were in bypass. Looks like that was the problem. Thanks for the help.
