Hi.
I own an HTP 140 amp mig welder, after buying a welding book, I tried to practice some welding. I got a piece of 1/8 inch mild steel and tried to butt weld it together. I had the setting on the highest level, I had a good stable arc, and used a forehand weld (about 15 degrees). The steel was sanded clean and was degreased. I'm using argon and CO2. I only have .023 wire in the machine. The pieces of steel were held tightly together and my travel speed was very slow. When I broke the weld apart, I had less than 1/16th" of penetration and the weld puddle looked porous. What am I doing wrong? Any help would be appreciated. Thanks.
