I decided to pull out my little 90 amp MIG welder this last weekend and practice what I have been learning in my welding classes. I am learning stick welding at my local tech school, and I like the stick welding a lot better so far... With the MIG welder the nozzle of the gun seems to cover up the weld puddle. Stick welding seems much friendlier because the weld puddle is so much more visible...
Weld puddle visibility
Hi Bill,
Keep in mind that in MIG, you only penetrate where the arc touches the base metal, so keep the arc in front of the puddle. Angle your nozzle so that you can see the back and sides of the puddle as well as the front. Also practice going in both directions. In the field, you will find that you will have to do that from time to time.
Sounds like you're having fun!
Thanks Rocky!
Yep, I'm having lots of fun. And I started going left to right and right to left almost on the first night. Seemed best to start that way and not face a steeper learning curve after I had mastered only one direction.
With my little MIG I have to drag the nozzle to maintain the arc. Stickout length I guess? I am using flux core.Bill C
