Did a search and it wasn't too fruitful...
I'm in the process of welding up a tie rod... got 0.120" wall DOM tubing as a sleeve... (it's got more cross sectional area than the original arm)... I cut the original rod in the middle and have to extend it about 2"... so there's 9" in length that's slid inside the DOM tube...
I've drilled twenty 1/2" diameter holes for plug welding... will also fully weld both ends (after removing the TREs)...
What's the best procedure for plug welding? Start in the middle and work outward... or start on the edges and work to the middle?
TIA
TIA
