Another weld critique
  • Another weld critique
    How do these look, butting two pieces together, machine is a HH175, .035 wire, heat range 2 (single straight pass in middle @ 3), 55-6- wire speed, 75/25 @ 20 with trigger pulled, .120 wall steel, pushing witha bit of circular? motion
    Here are some test beads the 3 heat range is the middle
      Here is the same tube to a piece of .25 flat, one is welding up, the other down.
        and the up
          Nothing top be ashamed of there. Looks good.
            The only thing that I could see is that the puddle looks a little "cold" and the 1/4" maybe could have had some more heat put into it.
            If I am wrong, please advise, as I am still learning.
            AtoZ Fabrication, Inc.
            Miller MM210--now X2
            Hypertherm 380
            Miller autodark hood
              For the tube, you're going too slow, evidenced by the humongous HAZ, but your penetration should be good. The tube to plate, looks good, however, I would point it more to the plate.
                I'd let him work for me.
                  HAZ ? What does that stand for?
                    Heat Affected Zone
                      Originally posted by Rocky D
                      Heat Affected Zone
                      Thanks.
