Welding next to a strong magnet
  • Welding next to a strong magnet
    I was using a 150# magnet to hold some material for welding. It seemed like when I was really close to the magnet the arc was extra erratic. Close is like the MIG nozzle touching the side of the magnet: HH-135; #1 volts; speed 10; .023 solid wire; C25 gas; doing tacks.
    Anybody every noticed anything like this??
    Yep. Get too close to the magnet and you will have to chase that arc all over the place. Heat is not good for magnets, a few quick tacks is about all you should do with magnet at weld joint (other side of joint) otherwise they will rapidly weaken. With tig, a strong breeze i.e. Nachos and Beer, will have the same affect.
      It is called arc blow. It is usually associated with SMAW on DC. I suppose a very strong magnet will cause it to happen with other processes. Interesting post.
      Respectfully,
      Mike Sherman
      Shermans Welding
        Thanks,
        I thought maybe I was dreaming. It was a 1"x6" 150# "pick-up" magnet holding a sheet metal patch in place for tacking, and at one point pulling the patch back to the desired level.
          Just an interesting note...we had automatic welders welding circumferential welds on .060" stainless rings, and there was a "wiggler" attached to the torch head. In actuality it was a magnet that oscillated the arc from one side of the tungsten to the other. It had timing controls and dwell, etc on it. Made a nice weld. It would make the bead wider as it "wiggled" the arc. One guy even had a small one rigged up to a hand torch. It was pretty slick.
