#6 wire
  • #6 wire
    I want to pick up the 6 wire for the 100' run to my garage but HD and lowes have it at $2 a foot
    thats $200 there
    anyone know where I can get some 6-3 romex, (NMSC) under that $2 per foot price?
    thanks
    Check out West Way Electric, almost to the bottom of the page. Don't know what shipping would be but $124.90 for 125ft of 6/3 romex is a good price.
    Bob Sigmon
    Dynasty 200DX and Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    O/A Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
    SkatBlast 970 Detailer
      Git'r dun, man
      thats $200 there
      thanks
      Hey Moody,
      You still screwing around with that wiring? I can get #6 4 conductor SOOW cable for less than $2/ft.!
      You could buy 300' of thhn, two telephone poles to string it from for the price of that romex.
      Go to your closest electrical contract supply and get what you need. Msc industrial supply co. has 6ga. thhn listed for $200.00 for a 500' spool. Your local supply may sell it for 150.00, so for the same price of a cob job you could buy 300' of the right stuff, conduit,etc., and do it right the first time. Your dad won't get hurt when he puts up the fence he's always wanted 20 years from now either.
      Miller Dynasty 300dx
      Miller XMT-304
      Lincoln SP-135
      Oxweld O/A rig
      Jackson Master pro-variable helmet
        thats $200 there
        thanks
        What are you useing that for? undergound or inside? if its underground I thought it was NMUSE cable ... IS there a E on there ? been too long! LOL or is it just US cable? No matter ... Y are you usering service entrance cable? Y not just UF undergound feed if its underground. If its inside Still same question Y are you looking at service cable and not normal romex NM ?? OR did something change in the last few years on wire... the SC ??? I would look for some # 6 stove cable for inside work. If its outside and underground you can get triplex thats for underground and that would be a world cheaper. Maybe im just tired as its about half a hour past my bed time!
        Sorry I just dont rember or understand how your useing that wire.
        OMS
        HH175
        Red Tomstone W/ HF for TIG
        Smith O/A X 2
        Harris O/A
        BridgePort
        MSC cut off BandSaw 6X12"
        And more!
        Shop Mechanic for Brinks Coin
          it will be going through the the joists of my basement from one side of the house to the other
          (from the sub panel to the welder outlet)
            6/3 is about $125. at homedepot. Only thing cheaper would be 4/3 aluminum SER cable. More common is 2/3 SER which is good for 100amp (residential). BTW, since you work part time as an electrician, cant your boss cut you a deal from his supplier? Or let you work it off?
            ______________________________________
            Bakery Mechanic
            Licensed Electrician
            check out: www.mattesbydesign.com great for vinyl lettering
            "Why do i ask such difficult questions? 'Cause i know the answers to the easy one's!"
            *****Heineken*****
            -any questions or discussions on 'gout' are welcome-
              Originally posted by TOMWELDS
              6/3 is about $125. at homedepot...
              but how long is it?
              I was gunna get a roll rewound from their huge selection but if they sell packaged rolls that are for less than ill buy it
              I rather use copper wire instead of alu. as copper seems to take more abuse
              im off to work now. I'll see what i can get from there.
                discounted wire
                Our local Lowes on Saturday Mornings restocks their wire spools and the wrap up their left-overs as remnents (sp?)... I picked up 120' of excellent condition #6-3 w/G***, UV resistant direct burial for 1/2 price, or about $1.00 per foot. They do not tell you its half price until ya talk to one of their "associates"... just ask!. Considering what others wanted it was a heck of a deal. Besides, the worse they can say is "no deal". Good Luck.
                edit: ***solid copper
                Russ
                MM175, 300/200 Thunderbolt,
                Miller Spectrum 125C, HH 125 EZ,
                Victor Super-Range O2/fuel,
                BWE,
                and...
                lots-of-junk slowly being replaced
                {previous login was KC8DZV, changed on 10.10.07)
                  im getting an even better deal
                  125 feet of 6-3 romex for $75 at Arch electrical supply
                  wagner electric uses them to order all the time and they seem to have good quality items
                    I just recently bought 50feet for $60 at my local Menards. I don't think there are Menards stores nation wide. But i checked home depot and it was quite a bit more.
                    HH 140
                    Hobart stickmate ac/dc
                    Sanborn 7hp 60gal comp
                    1950's Craftsman drillpress
                      You are wise to go with the copper. Al takes Al rated switches and outlets.
                      Dennis
                      Dennis
                      Thermal Arc 185-TSW
                      Millermatic Challenger 172
                      VictorO/A
                      Atlas Craftsman 12 by 24 Lathe
                      Esab PCM-875
                      Wholesale Tool Mill-Drill
                        OOPS
                        i just cut the price down again
                        i forgot...
                        i dont need 6-3
                        i only need 6-2 as the b&w are the hots and the ground is used
                        would not need that extra red wire
                          OOPS
                          i forgot...
                          i dont need 6-3
                          You installing JUST a plug for your weldor and nothing more? I thought you were installing a pannel in your out building? If your just running all that wire for a plug then no. You can use 6/2 but, if your putting in a pannel out there then you need 6/3 W ground.
                          OMS
                          HH175
                          Smith O/A X 2
                          Harris O/A
                          BridgePort
                          And more!
                            what im doing is taking breakers out of the main panel and putting them into the sub panel then putting a 2 poll 50 for the welder. ill use 6-2 romes to go from that 2 poll 50 to the 220v outlet in my garage
                            so the breaker for my welder will be in the original panel and the sub panel is there to open spots in the original
                              Dennis
                              These days, most all receptacles and panels designed to grip #8 and bigger are already rated for Al. I can't remember the last time I saw one that wasn't anyway. But always make sure. What kind of abuse are you expecting? I see no reason why not to use Al if available and cheaper and in a permanent installation. A lot lighter, just have to make sure your terminations are tight and use a little oxide inhibitor.
