Hi guys. I have a mm210 and a dial arc 250. On the mm 210 the voltage taps are 1 thru 7. what voltage do these taps represent?
Wire speed on the mm 210 dial is 10 thru 100, not inches per minute, any chart other than the one that is on the mm 210 gives voltage and inches/min. Is there a way to relate the 21o markings to voltage and wire speed. The dialarc 250 amp control dial is 1 thru 10, not in amps. Same problem, is this a miller twizzler? Any suggestions? Thanks
