How to improve weld
  • How to improve weld
    It is obvious that there are several excellent welders here. I am getting little pits in my welds it just does not look like a nice clean bead. when I am welding it sounds poppy it will run good for a while then starts to pop. Why would I be getting this? Could it be I need more shielding gas? It was running at only 10cfh and I think it should have been at 20. I have a HH 135.
    Thank you,
    byron
    You could turn gas up a little, but if there is no breeze I doubt you need 20. More than likely your wire speed is too slow. Crank it up a third to start with and see what happens.
      I will try that. Could it be I have impurities in the steel. What could I clean it with.
        got something
        hey man harvey's degreaser works great if you can find it anywhere.
          I wipe most stuff down with acetone to get it clean.
          - jack
            Thank you
            Now I am getting a lot of splatter why would this be?
              what brand of wire are you using ? some brands of wire are more prone to splatter than others. Also, it seems that I get excessive splatter whenever I let the electrode stickout distance get to great.
              - jack
                Set your gas at 20scfh for a start.
                  what gas are you using? CO2 will cause more spatter than C25
                    Read this section for help with spatter-free welds.
                    http://www.weldreality.com/short_circuit_under100.htm
                      Very helpful
                      I am using C25 gas, and hobart wire I believe. I just don't quiet get it it is almost seems like I can't keep up with the bead. Would it be possilbe to weld on setting 3 for power on an HH135 on 3/16" it seems too low.
                        BRYON.............TRY THIS SET YOUR WIRE AT 40 OR 50 ON THE WFS.........SET GAS AT 20-25 AND ADJUST LATER..........SET RANGE ON 3................LET US KNOW HOW IT TURNS OUT..........WE CAN FINE TUNE AFTER ELIMINATEING PEROSITY........................ROCK
                          Much appreciated
                          Wow thanks, I just didn't think 3 was going to get enough power to penetrate 3/16". I will do that tonight and report back. It is rather frustrating I haven't welded in about 4 years but I used to be decent nothing like some of you guys but I got the job done.
                          byron
