which steel is stronger.....and other quiries...
  • which steel is stronger.....and other quiries...
    Just getting into this tig welding stuff, lots of questions, but what is the trick to welding thin tubing without burning through?
    I took a course at our local college here last fall, and converted my ac/dc stick welder to tig, but im having a terrible time getting good looking and consistent welds on tubing.
    My main question however is which steel is stronger, hot rolled or cold rolled , I seem to get different opinions.
    any advice, would be appriciated
    thanx
    ed
    Steel Conan... you can always trust steel
    Ed,
    Cold rolled is stronger than hot rolled. It will have closer tolerances and the absence of mill scale makes it a lot nicer to handle and work with.
    Bill C
      Ed, Bill is correct, but I have seen more things made from cold rolled break than hot rolled. TIG puts enough heat into the CRS to make a good weld, it's only MIG that I would question. Other factors are joint design and application, too, so I'm not saying don't use CRS, just make sure you get enough weld on it. and if it is a large weldment I would stress relieve it.
      Mike Sherman can give you more informaton on it as to why.
