filler rod ??
  • filler rod ??
    What is the difference between gas welding filler rod and tig filler rod? Can they be used interchangebly?Thanks in advance.
    russell
    It's a poor mind that can think of only one way to spell a
    word." -- Andrew Jackson (1829-1837)
    Some can, but I know that some carbon steel TIG rods aren't recommended for O/A welding.
      You shouldn t use O/A mild steel filler rod for TIG, because it is lower quality then the TIG filler rod. To produce a high quality weld with TIG on mild steel you want a filler metal with the highest number of deoxidizer possible, because of this I generally use ER70S-2. If the ER 70S-2 isn t in stock I go with ER70S-6.
