thanks for your responses. i wish i had the option of using a 6010 rod but i am stuck with 7018. mike gave me some good advise that i am going to try. any other responses would be greatly appreciated also.
galvanize welding
BEBOPXXXXXXXXXXXXX.....................WELL YOU UNDERSTAND THAT WELDING GALVANIZED IS VERY HAZERDOUS TO YOUR HEALTH.....................VERY................... .....................ROCK
[email protected]
I've had to weld Galv. with 7018 before also,if possible grind the area to be welded first and then proceed,wear a mask even when grinding,i have worked with tons of Galv and have gotten sick quicker from grinding it than from welding it!What is IT?you don't want to know!wear a mask,get a fan and blow it the hexx away from ya!Good luck
When we were doing big Galv projects we had Speedglass fresh air helmets and also air vacum/purifier units to suck up the smoke.It was the one or two day projects were we just used regular masks and if you were not carefull you could get sick.
WELL I'VE HEARD OF THE MILK THING BEFORE............. HOWEVER I DO NOT SEE HOW THAT WILL HELP YOUR LUNGS. IT DOES COAT YOUR STOMACH THOUGH...................... USE A BIG EXAUST FAN, RESPIRATOR, AND DO NOT BREATH THE SMOKE........... THAT IS SOME DEADLY STUFF YOUR DEALING WITH.......................
ROCK...........[email protected]
