Carbide and HSS
  • Guest
    Originally posted by Al T.
    Is brazing the prefered way because of the lower temperatures required? Do the lower temperatures protect the hardness of the metal from being lost?
    I really don't know, I never studied the process. I only know they make door panels with honeycomb sandwiched together, and they put 'em in an oven and they come out brazed. Weight is a big factor in aircraft.
  • chip hayden
    does this question pertain to bi-metal bandsaw blades? if so, it's an autogenous weld with pressure applied, then tempered. the little welders designed for this job are the only way to go.
  • Al T.
  • Guest
    I believe it's called "furnace brazing" . we do alot of it here, at my plant.
  • Hobart Expert Rock
    AL...........I GIVE UP NEVER TRIED, THEY GET IT TO ATTACH TO STEEL SAW BLADES BUT DON'T THINK I KNOW THE PROCESS LET'S CALL THE HOBART SCHOOL OF WELDING TECHNOLOGY. 1-888-462-2789 OR E-MAIL THEM AT WWW.HOBARTBROTHERS.COM HAVE THEM GET YOU TO THE APPLICATIONS LAB AND TALK TO KRIS, IVAN, BUTCH, DENNY, ANY OF THOSE FOLKS WILL KNOW THE PROCESS...........ROCK.......... [email protected]
  • Guest
    You could, but I wouldn't trust it. Use silver braze.
  • Al T.
    started a topic Carbide and HSS
    Carbide and HSS
    Curiosity wants to know, can I weld carbide or high hardness steel with mig welder hh175?
    I do not have a need to do this, I just wanted to know if it can be done with my equipment.
