Pre-heating???
  • Pre-heating???
    Greetings all. I have a few questions about pre-heating. Is there a rule of thumb on pre-heating in regards to what the minimum metal thickness you should start preheating - I mainly work in steel. Also, what do you all use to preheat? I have a little propane torch that is pretty convenient ... will that work? Finally, how hot should you go with pre-heating, and how do you know when you are there? Awhile ago, I posted about having a few welds crack in some thicker steels right after taking the torch away, and the concensus seemed to gravitate toward lack of preheating. Ok thanks in advance for any and all advice.
    Ben
    I'm not to sure about the pre heating part of it but I do know if you were going to they make heat crayons. You can buy different heat crayon for different temps. When it reaches it's temp it turns a glossy color. That is when your metal is at the temp you want.
      I was taught
      anything thick or thicker than a pencil ,preheat to at least 22 deg. f
      on big jobs we use propane weed burners. welding supply sells temp. sticks that melt, at spefic temps.
        I don't pre-heat anything thinner than .750, unless the weldment is colder than 50°F, or the weldment is very large, like a box-scraper or something like that. For heavy weldments, I like to get the temperature up to 250 - 300° before welding. Temperature crayons (Tempil is one brand) work really well until you get the sense of how hot 300° feels on your face! I use an O/A torch to heat, but a high-BTU output propane torch would work well also.
        I should add that my experience on thick stuff is limited. I've repaired things, like Gannon-boxes and a loader bucket bracket, but I've never eally fabricated anything from steel thicker than .375 yet.
        Hank
        ...from the Gadget Garage
        MM 210 w/3035, BWE
        HH 210 w/DP 3035
        TA185TSW
          I will have to stop by the welding supply store and pick up some of those heat crayons - good tip for a newbie here. I will check back for any more suggestions/info on pre-heating.
          Thanks all.
          Ben
            With O/A, you blacken the metal with Acetylene, then heat it till it burns off. That's 250 to 300°. Metal should be at least 70° before welding to be safe.
              [QUOTE=Rocky D]With O/A, you blacken the metal with Acetylene, then heat it till it burns off. That's 250 to 300°.
              see that..........you learn something every day !!
              dawg
              God Bless America
                Freezer
                Sometimes I have to weld in the freezer which is -10f. I am welding on pallet racking that goes 8 pallets high and is made mostly of 3 to 4 inch channel.
                Are you guys telling me that I need to heat this up before I weld on it ???
                FreezerMan
                  FreezerMan
                  Depends. IF the material and the weld consumables are designed for the low temperature (nil ductility temp below the working temp) you may not need to. If there is very light loading and no shock to the structure, less citical, but I woud bet that is not the case with pallet racking.
                  I woud bet that you want to preheat, that you want to confirm the compatability of the consumable with the service, and you may want to check out a standard AWS procedure for the application. Proceures are based on material, service, welding process, etc., especially of there is a liability or safety component involved.
                    Ok Rocky - good tip, I have actually annealed sheet aluminum the way you described. I never actually knew the exact temperature range until you mentioned it, though. I wish the acet. was not so darn messy - I have a tiny room that tends to get really sooty really fast. Ok, thanks again all, and I will keep checking back.
                    Ben
                      FreezerMan
                      Here's an interesting read...http://www.disastercity.com/titanic/index.shtml
                        Hi Ben , there are many general rules of thumb regarding preheating. Before we get into that here is some preheat info :
                        [B]
                        REASON FOR PREHEAT[/B]
                        1. The most common reason for preheating is to reduce the cooling rate ( quench ) to help eliminate reduction of ductility of weld and HAZ . Obviously if the weld gets brittle ( loses ductility ) its not desirable !
                        2. Reduce shrinkage stress in a highly restraint joint ( weldment which does not allow the weld to move as it cools causes high stress in the weld ). With preheat, the shrinkage stress has more time to relieve itself in the hot weld
                        3. Reduce cooling rate to minimize underbead cracking ( 1st 2 reasons are more common )
                        NEED FOR PREHEAT ( for reason 1 )
                        Carbon Equivalent
                        The need for preheat is generally dictated by metallurgy of the base material. More specifically it is the Carbon content and to a lesser degree the amount of alloys in the material
                        Because its the carbon content which is the most significant contributor all the other alloys such as Cr , Mo , Ni etc are given a Carbon Equivalent value. For example, The %Chrome is divided by 5, but the %Ni is divided by 15 to get the Carbon equivalent. this is because Chrome has a greater effect on need for preheat than Ni does . Chrome helps greatly to increase hardenability of steels
                        Incidentally Carbon content makes a signficant difference in hardenability. The problem though is the better the hardenability of a material, the more the tendency to have reduced weld ductility ( weld gets brittle )...which kinda makes sense !
                        Fortunately steel manufactures know this and strive to control the C content
                        Won't bore you with the actual formula but just search under International Institute of Welding Carbon equivalent formula. You can also find online formulas that will crunch the numbers for you or you can buy "Preheat Calculator Wheels"
                        All these numbers are plugged into a formula which yields the carbon equivalent .
                        Thickness
                        The next determining factor is the plate thickness . If you think about it this makes sense. The thicker the plate, the more massive the heat sink ( to suck away the heat from welding ), therefore the thicker the plate the higher the quench rate. Recall REason 1 for preheating was to reduce the quench rate
                        For example for the very common T-1 type steels (quench and tempered ) typically
                        1/2" thick - about 50degF
                        3/4" thick - about 120degF
                        1" thick - about 200degF
                        1.5" thick - about 250degF
                        This is only an approximation because if the joint is highly restraint the min preheat temp increases
                        Rule of Thumbs
                        If you know the carbon content for the material a good rule of thumb is the points of carbon X1000 is the min preheat for
                        For example, if a material has .20% carbon, then min preheat is about 200degF
                        If you know the SAE classification of the material its real easy . The last 2 digits for the SAE classification is the approx carbon conent. For example, SAE4130 ( chrome moly ) is about 0.30 points of carbon . Preheat then is approx 300deg F . If you run the alloy through a preheat calculator using the carbon equivalent, it comes out a bit higher but for purposes of estimating its ok
                        Ductility and Preheat
                        As already stated, the need for preheat is mainly due to metallurgy and thickness. For example, if you were welding some quench and tempered plate such abrasion resistant ( AR400 ) wear plate. If the requirement for sake of argument is 150degF , it would be 150degF whether you undermatch with E7018 , or you want to use a alloyed electroded with great impact properties such as 1% nickel electrodes ( Nickel helps low temperature impact properties ). The electode chemistry has little to do with it
                        EXCEPT ..... ( always an exception )
                        When very low hydrogen electrodes are used the required preheat temperature decreases somewhat. For example if you were welding the above wear plate with E6010 vs a E7018-H4 you will find that the low hydrogen electrode is far more forgiving
                        When you will need prehat
                        Often people with smaller machines will need preheat not because of all the reasons above, but rather the machine does not have the current to give a good fusion ( weld looks cold ) . You see this with people welding aluminum all the time ( not really a great idea though ! )
                        You might also run into this if you are welding Quench and Tempered plate ( like T-1 etc ) or cast iron ( realatively high C content in cast irons )
                        If you work with race cars you might also run into CrMo tubing etc
                        If you are welding on relatively thin ( thinner than 1/2" ) I wouldn't get to excited about preheat on mild steels unless the plate is chilled ( outside ) . Often its more important to "put the torch to it" to help eliminate any moisture than it is to preheat it
                        If you want to preheat heavy plate don't waste your time with a small propane toch. use a Tiger torch ( inexpensive ), or Oxy Propane / Oxy Acetylene etc. Heating heads for torchs are pretty cheap
                          Pre Heat
                          Rocky, I had a 85 year old part timer that taught me that trick for aluminum, ,,Works like a champ,Jack
                            TRG-42 - GREAT lesson on pre-heating ... I am going to print this thread out to save all of the great information. I appreciate you taking the time to go over the reasoning and needs as well for pre-heat. That was all that I asked for ... and then some. Thanks again all for the help. I will start putting into practice what I have learned here and improve the quality of my welds. Thanks again.
                            Ben
                              TRG-42...
                              that's really good and understandable info.
                              Thanks a lot!!!
                              tjb
