I'll be building a wood splitter soon, and will need to weld a 1" thick mild steel wedge to the 7/16" thick flange on a mild steel 831 beam. I've never welded metal that heavy before. I have a Miller 180SD, and have been planning to use that in stick mode, DC, with 1/8" 6011 rod (cause I have a bunch of that rod on hand). I also have an old Sears 295amp AC buzzbox that I can use, if the 180SD doesn't have enough power.
I'm looking for suggestions on how to prep for this weld. There is going to be lots of force on this when it's done, so I want it to stay stuck! I'm planning on grinding the bottom of the wedge on both sides, where it sits on the beam flange (leaving about 1/4" in the middle), so I can get to the root. Tack, then weld on one side, weld the other side, wait for things to cool down, and repeat. Might need to repeat twice. Does that sound OK? What angle should I grind the bottom to?
What amperage do you recommend? Will the rod I have on hand work? Any special techniques I should know about for welding steel this heavy? Anything I need to be on the look out for?
Thanks in advance for your help.
Corm
Corm
