125 handler
  • mahee
    Thank you for sharing your problem!
    I thing there is need to refresh your machine or check its speed then repair, According to me there is just machine renewal problem. Thanks...
  • Hobart Expert Keith
    Does the unit click inside when the trigger is depressed?
    Keith
  • kikixus
    125
    thanks for the resonse ,No it has never reset ,for almst 4 years this the first problem that i had .
    Did your machine ever reset? Sounded like a thermal overload.
    Keith
  • kikixus
    started a topic 125 handler
    125 handler
    Hello all !, I have a problem with my 125 , i was welding some small pipe and after about 5 min. it quit welding ! the fan works and the push button in the back is in. what could be the problem ? I opened the case to check for anything burnt or blown ,but i found nothing. Any help would be appreciated.
    Thanks Henry
